J JaffaUK New member Joined Sep 8, 2008 Messages 14 Points 5 Sep 8, 2008 #1 Does anybody know what this stands for and what it does? It's written on the engine, but I'd never heard of it before I got the Bravo?
jug blessed are the apostates Parked in the garage Joined Nov 28, 2005 Messages 27,935 Points 3,763 Location Durham Sep 8, 2008 #2 its the variable inlet system, which includes a variator solenoid to adjust the inlet cam timing.
OP OP J JaffaUK New member Joined Sep 8, 2008 Messages 14 Points 5 Sep 8, 2008 #3 jug said: its the variable inlet system, which includes a variator solenoid to adjust the inlet cam timing. Click to expand... Thanks mate
bulldog5046 faster! FASTER!!! Parked in the garage Written a guide Joined May 8, 2005 Messages 9,053 Points 1,538 Sep 8, 2008 #4 jug said: its the variable inlet system, which includes a variator solenoid to adjust the inlet cam timing. Click to expand... Thats just Variable Valve Timing, most cars do that.... on the bravo/marea 20v VIS it has a 'gate' on the intake manifold which opens at about 4500rpm to allow more air to flow. the restricted intake is ment to increase torque at lower RPM Ry
Davren Moderator Staff member Uploaded 10+ resources/downloads Joined Jul 6, 2008 Messages 16,422 Points 3,885 Location London, UK. Sep 8, 2008 #5 bulldog5046 said: Thats just Variable Valve Timing, most cars do that.... on the bravo/marea 20v VIS it has a 'gate' on the intake manifold which opens at about 4500rpm to allow more air to flow. the restricted intake is ment to increase torque at lower RPM Ry Click to expand... They do like resurrecting old technology and giving it a new name. 1985 Croma CHT (Controlled High Turbulence it was called then) had 4 extra throttle butterfly valves, one built into each inlet manifold duct. Attachments Copy of CHT.jpg 82 KB · Views: 103
