Hi all,
first post so apologies for not knowing a right lot but here goes.
I bought a 1997 (P reg) fiat bravo 1.6 SX a few days ago... i got it in the knowledge that it wasn't working...maybe not the cleverest thing i've ever done!
I ride motobikes usually but want/need the use of a car as and when and although i don't no a right lot about cars wanted to have a play and see if i could get it running!
After seeing all of the problems with bravos on this site the first thing i did was change the ecu, immobiliser and barrels to set for which i do have the red key. Problem 1 sorted, i thought! If i put the key in the ignition the code light comes on and goes off after 2-3 seconds which seems to be right.
The battery was one bought by the previous owner which seems to be fine, although it's got a 4 year warranty so i'll get them to check and replace as necessary.
What should i check next, i've checked all the fuses i can get my hands on and all semm to be working, all the electrics ie sunroof, windows, lights, radio are working without fail but the car just won't start!
When you turn the ignition is sounds like it's trying to start but just won't fire up, really demoralising!
Any help greatly appreciated and thanks in advance, i thought next was to check spark plugs, any ideas on how to check they are...sparking? and if that fails fuel pump?
Thanks all
Jamie
Thanks all
Jamie
