| Brava engine stalls on braking This problem has recently shown up on my 1.8 Brava (year 2000). When braking, particularly on a slight downhill slope, the engine will cut out. This doesn`t happen all the time, just now and then. Does anybody have any ideas on what might be going on? Thanks.
| Does it sound rough or shaky before it stalls?
| | #3 | ||
| Re: Brava engine stalls on braking Well it hasn`t been running as "sweet" as normal but nothing that would overly concern me.
| | #4 | ||
| blessed are the apostates | Re: Brava engine stalls on braking check all 4 plugs, comparing them to identify an ignition problem on 1 cylinder (suggesting a fault coil). if all 4 look the same then try cleaning inside the throttlebody. | ||
| | #5 | ||
| Re: Brava engine stalls on braking Thanks for the advice Jugs I`m working away at the moment but I`ll try your suggestion when I get back and let you know the outcome.
| | #6 | ||
| I Helped :D | Re: Brava engine stalls on braking Just thinking out loud so at the risk of sounding like a noob :P The clutch and brakes share the same reservoir is the fluid level ok? perhaps the clutch isn’t allways going all the way down and its just gripping therefore stalling your car. Although i guess you mean gentle breaking without touching the clutch yet :P
__________________ ![]() Need a passenger front wing for My Bravo. Colour code 387/A Last edited by Adrian_Bravo_96 : 24-07-2008 at 20:15. | ||
| | #7 | ||
| Re: Brava engine stalls on braking Sorry for the delay, I`ve been working away. Anyhow, I changed all the plugs though they seemed in pretty good condition. Cleaned out the throttle body, A good squirt of redex in the fuel tank then went for a blast. The problem hasn`t recurred yet though as I said it is very intermittent. The engine seems to be running a bit better than before. I assume that if there was a fuel or ignition fault then it will take a little while for everything to reset. This car is used for a lot of fairly short journeys, probably 60 journeys of eight miles or less per week. Should I be paying particular attention to any area of servicing? Thanks very much for your help
| | #8 | |||||||||
| | #9 | ||
| blessed are the apostates | Re: Brava engine stalls on braking | ||
| | #10 | ||
| Re: Brava engine stalls on braking Sorry fellas, problem is back again ! Any further suggestions ?
| | #11 | ||
| blessed are the apostates | Re: Brava engine stalls on braking try crank sensor | ||
| | #12 | ||||||
| | #13 | ||
| Here to help | Re: Brava engine stalls on braking My lack of knowledge on the Fiats is going to come into play here... Ford's Renault's Peugeot's etc. Suffer a similar problem. It results from a dirty/worn idle control valve and is usually apparent when approaching roundabouts or junctions. As you press down on the clutch and the revs drop the engine stalls. This does not happen every time though. It might be what Jug was pointing to when he said clean the Throttlebody. So apologies if that is the case.
__________________ Coupe 20VT, beautiful design, straight 5 cylinder turbo charged engine, mildly tweeked to 250BHP 0-60 in 6.0 and 155 mph = + + | ||
| | #14 | ||
| | #15 | ||||||
| Brava - Stalls when idling | wspxk01 | Bravo/a > Technical | 6 | 13-09-2006 20:37 |
| Engine Stalls with A/C on | cobain677 | Punto | 3 | 12-04-2006 17:37 |
| Engine Stalls with A/C on | cobain677 | Palio | 0 | 11-04-2006 13:11 |
| brava stalls when hot | andyt | Bravo/a > Technical | 2 | 20-09-2003 22:39 |
