Bravonige
My Bravo has just developed a click when I depress the clutch. Same happens when the clutch is released.
I read elsewhere that it could be a White Cap which could be worn and needs greasing. Does anyone know where this cap is? I looked under the clutch pedal (inside the car) and the click is coming from under the engine compartment. Does this suggest that I need a new cluch cable or worse still a new clutch and cable? Bravo has done 60K and I am not heavy on clutches (last car, a Citroen did 120K on first clutch!).
Any views and thoughts would be gratefully appreciated. I am new to the Forum but impressed with all the info.
Cheers for any help!
Nigel
Nigel
