FIAT Auto Specialist Team
Thread Tools
Old 10-07-2008   #1
fiat brava starter motor fault
can anybody tell me , i got a new battery last week , and still every now and then it won,t start , as if its got a flat battery , a guy told me it could well be a dodgy starter motor , i need advice on this. tnx
laner is offline Reply With Quote Quote
Old 11-07-2008   #2
jug
blessed are the apostates
jug's Avatar
Trader Rating: 1
jug has donated!
Re: fiat brava starter motor fault
yeah it'll be the starter motor if it does nothing at all when you try to start.
obviously if the engine is turning voer when you try to start it then the starter motor is doing its job and it must be something else (usually crank sensor)
2.0 twinspark veloce
jug is offline Reply With Quote Quote
Old 09-01-2010   #3
Question Re: fiat brava starter motor fault
i am currently having this problem in this lovely cold weather we are having. the motor is turning the engine but very slowly like a flat battery and is still the same with a brand new battery fitted. could it be moisture in the starter is frozen and making it sluggish. average temp round here has been -8c,
Also is it possible to remove the starter without raising the front off the ground. not possible due to 1.5ft snow and parked on hill.
any help really appreciated.
thanks.
richard
rbramm is offline Reply With Quote Quote
Old 09-01-2010   #4
Trader Rating: 5
fingers99 has donated!
The moisture thing seems a bit unlikely to me. Try either a jump
jumping car + to dead car +
jumping car - to dead car chassis earth (or solid metal part of engine)
Or/and try a single jump lead from battery -ive (on your car) to near the starter motor (your car).
Winter shows up bad batteries and poor earths (and 85% of electrical problems are probably bad earths).
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 12-01-2010   #5
thanks for the tips fingers.
have tried your suggestions and it is still the same. could this be the starter beginning to seize or something. if i take the plugs out she will turn over but still slowly. not as fast as it should. think i might just have to get a new starter.
she just wont turn fast enough to fire.
Thread Tools
(G) Starter Motor on Fiat Brava FiatBrava1400sx Bravo / Brava 3 03-01-2007 10:25
(T) Brava 1.4 starter motor bijou Bravo / Brava 2 26-06-2006 10:29
(T) punto 90 elx, starter motor and electrical fault tillylou2003 Punto (Mk1) 9 31-05-2004 06:58
