The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Bravo / Brava
Old 01-07-2008   #1
Trader Rating: (0)
3 problems in one and no ideas
I know some will look at this and think this has been asked before but I have looked through hundreds of posts and can’t find anything that could be doing this.
On my Bravo 1.4 (97 model) I am having problems starting the car, not the first time in the morning that will work fine but if I stop and then try to restart the engine without waiting for 10-15mins then it will ether not start or when it does I will have to hold the accelerator down to keep the revs up for about 30secs.
Ok so far I have found posts about starting up but….. When I am also driving the injection warning light comes on and in fact the car seems to drive a bit nicer and the idle speed seems to be running fine. But when the injection turns off say after 15 – 20mins of driving then its like I can feel the accelerator go down a bit without me doing it and if I take my foot of the pedal it will stay at the same speed this will then happen for about 20 secs, if I put the clutch down then it will just rev like crazy for 20 secs. Then most times the injection light will come back on and the accelerator won’t give me any problems again????
Now I think all these things are linked together and hopefully it’s fixable but I have no idea on where to start. As I have taken it to a fiat dealership in Berkshire and they said there where no error codes in the ECU???? Any help or advice you be greatly appreciated.
wimbly is offline
Old 01-07-2008   #2
jug
blessed are the apostates
jug's Avatar
Trader Rating: (1)
jug has donated! United Kingdom
Re: 3 problems in one and no ideas
actually everyone is reading it and thinking its in the wrong section, but dont worry its not your fault fiat recycle car names.
you have 2 problems; a dirty throttle case and a faulty crank sensor. both common, and neither trigger fault codes.
jug is offline
Old 01-07-2008   #3
Trader Rating: (0)
sweet thanks for the quick responce. sorry if its in the wrong section.
I'll have to have a look through the Hayes manuall tonight to see if it is something I can do or if I need to get a mechanic to look at it. I'll let you know.cheers once more.
wimbly is offline
Old 06-07-2008   #4
Trader Rating: (0)
hi
had same problem bought set of leads and crank sensor took 20 mins to fit easy job solved problem on mine and mates 10 mili bolt holds crank sensor drivers side bottom of pully next to plastic case
hope it solves yours
good luck
kermit is offline
Old 07-07-2008   #5
Trader Rating: (0)
Thanks Kermit,where did you get the crank sensor from and how much?
Hope to get this done this weekend weather permitting.
Also what is the preference for cleaning the throttle body 1: cleaning it in situe or getting a cleaning product that gets added to the fuel??
thanks for any replys
wimbly is offline
Old 08-07-2008   #6
jug
jug's Avatar
Trader Rating: (1)
fual additives cant clean the throttlebody, no fuel goes near it. you need to remove the air intake and then remove the throttlebody to clean it on both sides of the butterfly valve. a spray of WD40 on a rag does the job nicely.
jug is offline
Old 08-07-2008   #7
Trader Rating: (0)
Thanks for confirming that for me Jug will try to look at this at the weekend as long as its not raining of course.
wimbly is offline
vB code is On
any ideas? 1.2 bravo running problems emily Bravo/a > Technical 4 19-11-2007 10:35
51 Punto steering problems Any ideas? lsgraham_uk Punto > Technical 13 30-01-2007 19:23
Still got problems, any more ideas guys? Randomman Cinq/Sei > Technical 8 12-04-2006 21:13
98 Punto 90elx Major problems, any ideas? Shermanator Punto > Technical 1 15-05-2005 11:39
CONSTANT problems with automatic clutch! any ideas Lisa82 Cinq/Sei > Technical 0 25-02-2004 15:53
