The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Bravo / Brava
Old 28-06-2008   #1
Trader Rating: (0)
timing marks needed for a bravo 1.2 2000
does anyone know where the timing marks are on my fiat bravo 2000 1.2 it broke the timing belt i think it might be ok if i can get the timing marks
007sparky is offline
Old 28-06-2008   #2
Trader Rating: (0)
Re: timing marks needed for a bravo 1.2 2000
Hi is it a 1.2 16v? just changed the head gasket on mine and there is no timing marks. You have to set the pistons using fiat tools or 4 rods the same lenght till they are all the same height and locate the notches on the cam shafts.best to remove the alloy cap on the side of the head extention and the 2nd from right rear alloy cap.
You might want to do a compression test as you may have bent a valve? not much clearance in the head.
FixItAgainTomorrow
madasapike is offline
Old 30-06-2008   #3
jug
blessed are the apostates
jug's Avatar
Trader Rating: (1)
jug has donated! United Kingdom
there are no timing marks; and it isnt a safe engine, so you'll almost certainly have bent valves.
jug is online now
vB code is On
timing marks???? !!~~help~~!! parky Marea 5 15-07-2008 09:08
marea 2000 timing marks wolfe01 Marea 3 14-07-2007 08:37
timing marks SHOT Punto 2 13-09-2006 09:45
help needed with timing marks asap :( tccat11 Punto > Technical 0 24-11-2005 16:43
Timing Marks? Help.. Miketw Bravo/a > Technical 1 14-06-2005 18:51
