The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Bravo / Brava
Old 24-06-2008   #1
Trader Rating: (0)
Heater blowing fuse
I've had my brava for just over a week now without any problems. I usually use the heater on setting number 1, unless I need to get rid of condensation on the windscreen fast. I've never had to use the heater on fast yet. The problem is if I put the heater above setting 2, it sometimes blows the air out but its doesn't seem to be very powerful either that or the fuse blows. I've replaced the fuse with the recommended one which is 20. Has anyone else had this problem? Or is my heater on its way out? The heater works perfectly on setting number 1. The car itself has done 35,000 miles and is a W reg.
adgloride is offline
Old 25-06-2008   #2
jug
blessed are the apostates
jug's Avatar
Trader Rating: (1)
jug has donated! United Kingdom
Re: Heater blowing fuse
your blower motor may be full of crap, usually leaves. its under the glovebox, try removing it to see if its clean.
failing that, the speed controller is shorting. if you follow the wires from the blower motor they go directly to the speed controller. try replacing it with a scrapyard part (couple of quid)
jug is offline
The following user says "Thank You!" to jug for this useful post:
adgloride (25-06-2008)
vB code is On
Fuse keeps blowing ShadowUK Bravo/a > Technical 6 13-05-2008 14:44
fuse blowing bunny11uk Ducato 0 14-04-2008 21:39
Fuse keeps blowing s786m Cinquecento / Seicento 9 20-03-2008 08:17
Fuse blowing and layout GeoffSt Ducato 0 13-01-2008 20:17
fuse blowing??? brazzy2k1 Bravo/a > Technical 0 18-06-2004 03:35
