| Fiat Brava Timing Belt I'm a new Fiat Brava owner, I've had the car about a week. Its a W reg 1.6 100SX. I've been reading the forums about the timing belt breaking on the Brava. I've had mine serviced and its got a 12 month MOT but I don't know when the timing belt was last changed. I was reading somewhere else and a post was saying that the timing belt problem was on the brava V reg and the older models. Am I safe as mines a W reg? Or would you recommend I get the timing belt changed right away?
| | #3 | ||
| Get busy livin' | Re: Fiat Brava Timing Belt
__________________ ![]() Please thank me....please ![]() | ||
| | #4 | ||
| Forum Moderator | Re: Fiat Brava Timing Belt If your not doing it yourself get a good garage to do it, these engines have to be timed exactly with the correct timing tools.
| | #5 | ||
| You can't fool owls. | Re: Fiat Brava Timing Belt If it's W reg chances are it's either had 1 change or none. It's due it's 2nd change anyway (about 4 years) so get it done. It's expencive to do it the other way and start replacing valves... | ||
| | #6 | ||
| blessed are the apostates | Re: Fiat Brava Timing Belt there is no timing belt problem with the 1.6, but it must be changed every 72k or 5 years, whichever comes first. it is very sensible to get it done earlier. if you dont know when it was done then you need to get it done asap. | ||
| | #8 | ||
| blessed are the apostates | Re: Fiat Brava Timing Belt chillax david i said "it is very sensible to get it done earlier". exactly how much earlier is up to the individual. | ||
| | #9 | ||
| Re: Fiat Brava Timing Belt Thanks for all the replys. The Brava only has just over 35,000 on the clock. I'll try and book it into the garage for next weeks and get it done.
| For Sale: Fiat Bravo timing belt cambelt Genuine Fiat (FIAT Bravo / Brava Parts) | v17ayc | For Sale / Wanted | 0 | 27-04-2008 23:38 |
| For Sale: Fiat Bravo timing belt cambelt Genuine Fiat (FIAT Bravo / Brava Parts) | v17ayc | For Sale / Wanted | 0 | 27-04-2008 23:37 |
| For Sale: timing belt / aux belt / fuel filter 1.8 16v (FIAT Bravo / Brava) | jug | For Sale / Wanted | 0 | 07-09-2007 13:46 |
| What's Your View (Fiat Brava 1.2 timing belt gone) | Angua2 | Bravo/a > Technical | 21 | 08-08-2007 11:52 |
| Brava Timing Belt | doctorblick | Bravo/a > Technical | 3 | 16-10-2006 14:29 |
