Because of some alternator problem of my car, the battery was left disconnected for weeks. The alternator has been changed recently.
After reconnecting the battery, I noted:
- an unsteady idling (the revs drop until the motor almost extincts itself but then the ECU kicks in and makes the motor rev again, only for it to slow down again shortly after...)
- for some minutes during initial driving, the motor idled for some times making some intermittent knocking noises
- some kind of "sudden loss of power holes" appeared which means that the motor has sudden misses - as if somebody turned the ignition of for a fraction of a second - this happens only in the partial-load operational range. I never yet experienced these "sudden holes of power loss" when driving with the accelerator at the floor...
- I cleaned the injection system with some additive - to no avail. However, during the time the additive was in the fuel tank, the above effects occured rarely.
- fuel consumption dropped to a magnificent 43.58 MPG (UK Gallons) which is 6,48 l/ 100 km (corresponding to a theoretical range of 489 miles not too bad for a Fiat bravo 55 kw 1,4 litres 12V which normaly needs 20 percent more fuel.
those sudden power losses are quite annoying on the autobahn. It only happends for a fraction of a second, but it happends repeatedly and seems to happen more often now...
before the old (faulty) alternator gave up, there was some problem with voltage which triggered the airbag light and let the battery sputter out acid with a fast rate.
The motor had been running too rich during about half a year before because of a defectuous thermostat (which was open all the time cooling way beyond the need).
by the way, on the first drive after the new alternator was fitted, I smelled something burning and some minutes afterwards, the 20 A wiper fuse blowed, it keeps blowing since - I have to wipe the car by hand...
Any ideas what's going on now?
