| Advice please leak on water pump? Hi again right a few weeks ago i had the water pump and Belt changed. everything on my car was running fine no overheating just had to keep checking coolant level make sure it was fulled up enough after new pump replacement. I've been driving the car to collage and after i finish i look to see coolant level and it seems to dropped a little not much..so i top it up. Then yesterday i went shopping came back and coolant was coming from the area were the water pump is leaking very close to my oil filter. could this be my new pump is faulty? or might be the liquid sealant needs redoing? Also will i need to replace the cam belt again if it is the water pump? Thank you for any advice yvette
| Re: Advice please leak on water pump? Take it back to the garage that did the work, they should repair it FOC.
__________________ ![]() Fiat Bravo Haynes Manual, Fiat Bravo & Fiat Coupe Workshop Manuals and Fiat Bravo Owners Manual on CD £5 Delivered. | |||
| | #3 | ||
| blessed are the apostates | Re: Advice please leak on water pump? ![]() garage have buggered up; then need to remove water pump and do it properly this time.
__________________ ![]() | ||
| water leak! | big rich | Bravo/a > Technical | 19 | 18-07-2007 20:23 |
| Where does the water leak from if heater matrix has a leak? | BrotherBud | Bravo / Brava | 4 | 10-07-2007 16:21 |
| Water leak | Savage | Lets Talk FIAT | 2 | 21-05-2007 08:39 |
| water leak | Pauline | Cinquecento / Seicento | 2 | 08-03-2006 21:41 |
| Water Pump major leak | red_cinqo | Cinq/Sei > Technical | 2 | 25-10-2004 22:10 |
