| HGT injector light My injector light keeps poping up, and makin my car run ruff. when the light is on and a put my foot down it turns off and runs fine agian. its problely doing it twice a day. and my fuel consuption is very poor. i have tried a bottle of injector cleaner (which neva worked) and now gunna test my injectors but do i test them the same as you would on 1.6 of 1.8???
| Re: HGT injector light as ive been taought from here, more than likely a MAF issue. give it a good clean with alcohol based cleaner. or get a new one if you can, got onew for a round a tenner off ebay! and couple quid posted if you like
| | #3 | ||
| Bravo Bravo | Re: HGT injector light Sorry to jack the thread, but what cleaner specifically should I use, not sure of any makes which would do the job?! Thanks
__________________ T 1999 BRAVO HGT 2.0 5CYLINDER 20VALVE - Red Dot Re-map . GSR Induction kit. Sports 200 cell catalyst. Powerflow cat back system. 170BHP 127FT-LB | ||
| | #4 | ||
| faster! FASTER!!! | Re: HGT injector light Wynns carb and injector cleaner Ry
| | #5 | ||
| Re: HGT injector light sound will give it a blast. thanks
| | #6 | ||
| blessed are the apostates | Re: HGT injector light for MAF cleaning i use an alcohol spray, such as this one from maplins @ £3.29 http://www.maplin.co.uk/Module.aspx?...C=SO&U=strat15
__________________ ![]() | ||
| | #7 | ||
| Re: HGT injector light It's not just a faulty MAF that can make the injector light come on. A dodgy lambda sensor amonst other things can cause it to come on too... and make the car run rough.. Best bet is to take into a decent friendly garage and get a diagnostic test done. That should give you a definitive answer to the fault. If it does turn out to be the MAF... stay well away from those cheap ones on eBay, they are utter rubbish and you'll get the same problem within hours.. Genuine Bosch ones aren't cheap.. Fiat will take £180ish of your well earned cash.. they can be bought cheaper, but make sure they are genuine parts.
| | #8 | ||
| blessed are the apostates | Re: HGT injector light while i agree a diagnostic is the best way to find out what is wrong, it is also expensive, so you should always try the easy common sense things first. for example unplugging the MAf and then driving to see if you get more power above 3000rpm is free and instantly tells you if the MAf is causing powerloss. you can visually check the condition o flal sparkplugs to identify over fueling or under fueling or a problme on one specific cylinder. you han go to an MOt testing station to find out if your lambda is ok for free (if you ask nicely). then if you were still stuck a diagnostic would be your only choice. at £50-65 and with no guarantee it will help, a diagnostic isnt something to rush in to (neither is randomly buying new sensors hoping to get lucky)
| Key code light DOES NOT COME ON, injector light on. Engine turns but does not start. | bravovarb | Bravo / Brava | 8 | 1 Week Ago 11:38 |
| Fiat bravo hgt injector light on | bigbeamerboy | Bravo / Brava | 9 | 24-12-2007 01:35 |
| injector light | levemir | Cinquecento / Seicento | 1 | 23-10-2007 21:20 |
| fuel injector for punto hgt | matty_oakley | Punto > Technical | 3 | 12-04-2007 22:34 |
| The key code light and fuel injector light stays on | nena_k | Lets Talk FIAT | 0 | 18-08-2004 07:21 |
