I really hope someone on here can help me. I'm new to the forum so please be gentle!
I have a 1999 T reg Fiat Bravo 2 litre 20v 5 cylinder and am having major problems starting it!
The only way to get the car to start is by setting the alarm with the blue key, disconnecting the main battery and then waiting for the alarm/immobiliser back up battery to run down.
Once it has run flat, if you then reconnect the main car battery, switch off the alarm with the blue key and turn the ignition key, it leaps in to life!!
It will then tick over and run perfectly until the ignition is turned off and it won't start again until you repeat the above process!! :bang:
HELP!!!!!!!!!!!!!
Does anyone have any idea what is wrong and more importantly how do I fix the problem??
Helen xx
HELP!!!!!!!!!!!!!
Helen xx
