I have fitted my tweeters behind my door mirrors on the plastic base. I have elec windows so i have room there. I fitted my crossovers in the arm rest in the front door (not visible), if you remove the door card its hollow. Either use 3M sticky pads and stick them in there after the wirings done or screw them in like i did. Remember all my wirings in the door, no need to mess going into the car and rewiring. I also have the original fiat tweeters working too.
For the rear, i have the tweeters in the C pillars mounted high, the crossovers are screwed to the sidewall of the carpet in the boot, a small hole and the wires secretly disappear.
In case your wondering i have components all round.
Also for an earth depends where the cable is, front of the car, in the boot etc. As jug mentioned theres a good earth in the boot. I have my sub connected to a bolt found on the drivers side, you'll need remove most of the the plastic trim to get to it. Not a hard job.
