General window regulator??
jake_6_9
lincolnshire
my passenger side electric window wont go up with the passenger side switch, its goes down with this switch but not up, i have to do it up with the drivers side switche's, could it be a problem with the regulator etc becuase im also having problems with interior light not coming on when the drivers side door is open and then bulb in the driver side electric windows switch not working which i think is just a blown fuse?? could all this be related?? thanks
the bulb is actually a tiny LED, they commonly fail.
if it goes up from driver's side then problem must be the pass side switch or its wiring.
interior light problme si the door switch, its a little pin switch, test it and try some WD40 on it.
check the main wiring connector for the pass door is securely fitted, it is in the doorway and is round black plastic, you screw it to connect/disconnect
