circolo
Member
With reference to this post: http://https://www.fiatforum.com/bravo-technical/135724-damn-pilot-bearing-i-think.html
I think this must have been an early warning that my clutch slave cylinder was in it's road to failure.
Drove down to the folks in Shoebury, on the Essex coast on Saturday. Went to move the car, as I was going to check my headlamp alignment against the garage doors, compared to the folks Punto's headlamps, (which has just passed it's MOT).
Anyway, clutch feels weird, and then I release, even though I've depressed the clutch, I'm still on biting point. Took the car out of gear, waited a moment, tried again, and the same scenario: initiallly feels fine, then the biting point gets lower and lower, and then I can't engage any gears.
Managed to park the car back up on the drive. Opened the bonnet to see a small trickle of fluid coming from the cylinder on top of the bell housing. (After looking at the Haynes manual, and this forum, I now know this is the slave cylinder).
Is this quite a common failure?
I'm considering doing this myself. The new part should arrive Tue/Wed this week at the folks house, they have a big drive, so that makes life easier.
I've checked the Fiatboo guide, which is very clear. Only one thing I really want to double check - I have a brake bleed kit. Essentially its a tube, with a non return valve on the end of it. For bleeding brakes, it makes the job a "one man" job, as you can pump the brake pedal to push fluid & air out, but when you release the brake pedal there is no return of the fluid & air back into the bleed nipple because of the one valve.
Would this be the same method for fitting a new slave cylinder, with this brake bleed kit? ie: I can attach the tube securely to the new slave cylinder on its bleed nipple, and pump away, checking from time to time on the progress until I see no bubbles in the fluid?
The alternative is for a mobile mech to do the dirty work, but tbh I think I'd prefer to do this myself, particularly if I can be thorough and do just as well with the job.
