re: Bravo '98 1.6 16v
I usually have a bit of trouble starting the car. After waiting a few seconds it usually starts the second time but occasionally needs a third go. I'm thinking maybe there is a problem with the spark plugs or starter motor?
The starter is probably the original and i'm not sure if the sparkies have ever been changed either. How often should they be changed?
Someone has told me that Bosch plugs are good ones. But is it easy to fit new plugs? Apart from a torque wrench and a feeler gauge do i need anything else- or is it a simple swap over?
Also i was thinking of booking it in at a garage for a normal service. For stuff like:
and maybe a few other bits n pieces. But i checked before and they charge around £120 for the standard service. is this about right or too expensive?
The cars only done about 75k so far. Are there any parts in particular i should service first? Cam belt has been done in the past.
thanks for any advice given
- engine oil change
- renew oil filter
- brake pad/disc check
- radiator coolant renewal
- new spark plugs
