General no spark brava
steve.cleethorpes
hi there first time post from me, ive just bought a brava 1.2 sx80 for my daughter, it was running but my nephew who i bought it off put new plug leads on and now it wont spark at all, the only reason its had new leads is because one was damaged, im very frustrated can any one help please? any advice gladly recieved, many thanks... steve:bang:
First of all welcome to the forum.Check the connection cable to the coil maybe its loose(that the leads end to.) If you not find any loose or problem there maybe you have a coil problem and needs replacing.
hi is the coil the distributor where the plug leads go in ? if so ive bought a new one of those and still no spark, some one help please:cry:
thanks to everyone for the help, still no spark looks like i got to buy her a car that works oh well thanks again
if the key code light is remaining lit then the immob is the problem, if the key code light is going out then the crankshaft position sensor is the most likely problem.
