| help needed! what can i fit? (head unit) can anybody please tell me i have a brava sx 1.4 96 what can i fit as a head unit. Can i fit two head units, one for a cd/dvd player, and anther for a screen, or is there not enough space? Can a fit a whole unit which is a dvd unit but is 7inches across including the whole unit? Any help is greatly appreciated. thanks!
| Bravo 155 HGT | Re: help needed! what can i fit? (head unit) You'd need to modify the whole centre panel to be able to do that, folks have done it before, but it sounds like alot of work.
__________________ Loosening Dirt, Degreaser, Film Remover? What to use? Unusual CODE Problem - Bravo HGT ![]() Drives: Bravo HGT 155 Nov 2000 - Vroom Yellow ![]() ![]() | ||
| | #3 | ||
| blessed are the apostates | Re: help needed! what can i fit? (head unit) you will be able to fit a single DIN sized headunit if you remove the original headunit and fit an adapter. | ||
| | #4 | ||
| Re: help needed! what can i fit? (head unit) thanks! could i not fit another DIN where the ashtray/rubbish tray is if i took that out?? thanks (i am trying to fit a dvd player with two different units)
| | #5 | ||
| Re: help needed! what can i fit? (head unit) if your any good at fibre glassin or plastic welding then yes you can modifiy the steering wheel even to fit one lol
| | #6 | ||
| Re: help needed! what can i fit? (head unit) if the gap the adpater goes in is the same as the 2001 1.2 sx bravo, then all you need is an adapter, to take up the gap and hold the cd/dvd cage. and then a cd/mp3/dvd playade by quite a few (made by a few companys pyle,ripspeed) this is an all in one it has a 7inch tft flip up screen, i can have the ps2/3/xbox connected, my phone so i can play music through the phone and out the car speaks, two amp outputs, closed ![]() closed side ![]() open ![]() open side ![]() note that the unit open or closed sticks out from the adapter bout 2/3 cm cause of all the wires, the lack of space at the back (blame fiat) and that if it fit flush the screen wud not open!
__________________ Car is back on the road and a new wheel is here ![]() ![]() ![]() | |||
| How to fit a 16v Fire engine in a Panda | panda-sport | Panda (Classic) | 25 | 05-04-2008 21:50 |
| Die Hard!!! | The Negotiator | Leisure Lounge | 27 | 24-04-2006 21:20 |
| Punto mk2 aftermarket head unit wont fit? | PuntoPodam | I.C.E | 3 | 15-01-2006 17:00 |
| New Head Unit Problems - Help Required | Punto_Lassie | I.C.E | 5 | 16-10-2004 15:05 |
| Modifying the AD185M head unit... | Weekend driver | I.C.E | 3 | 10-04-2003 02:24 |
