The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Bravo / Brava
Old 18-12-2007   #1
Trader Rating: (0)
Redex engine cleaner?
Hey guys
Does anyone know if it is worth using redex engine cleaner for the car? Its a Brava 1.4..Redex is that stuff that u throw into the petrol tank and they say it cleans the engine....Is it worth using? and is it safe?
thanks!
mike.said is offline
Old 18-12-2007   #2
Trader Rating: (0)
Re: Redex engine cleaner?
Originally Posted by mike.said View Post
Hey guys
thanks!
Hi Mike i have herd alot of people who say that it is good to put redex in your car. i put redex in my bravo hgt 2L 20v since then everytime i start my car the injector light stays on if i turn it off then back on again it goes out. so personaly i wouldn't use it. craig
tubbies7 is offline
Old 18-12-2007   #3
Trader Rating: (0)
ok thanks for lettin me know! but did it make any differance to the performance of the car?
Old 18-12-2007   #4
Is it me?
Trader Rating: (0)
richardwp has donated! United Kingdom
I occasionally use Diesel Redex if I've been using supermarket fuel regularly. It does seem to perk the car up a bit. Don't bother if I've used Shell, BP etc which already contain adequate cleaning agents (don't use Esso as they're b******s see http://www.greenpeace.org.uk/climate/stop-esso). I've found Wilkinsons are cheapest for Redex at less than £1 a shot.
richardwp is offline
Old 18-12-2007   #5
Trader Rating: (0)
no it was just the same
tubbies7 is offline
Old 18-12-2007   #6
Fiat = Ticking BOMB!
Noclu3's Avatar
Trader Rating: (0)
Noclu3 has donated! United Kingdom
for Diesels use... http://www.fasteronline.co.uk/Miller...e3d85f42f05dc0
It must be the "power sport 4" because the older "power +" is not Euro IV compliant.
If my reply has helped you please give me a
(03) Fiat STILO JTD[115 + Red-DotMagic!] Multiwagon Dynamic - 1st ever Fiat (God I hope I made the right choice! )
Please don't complain about my spelling
Noclu3 is offline
Old 18-12-2007   #7
Noclu3's Avatar
Trader Rating: (0)
http://www.millersoils.net/1_Millers...UTO_RETAIL.htm
Some reading. Can be found alot cheaper.
They do petrol additives too.
Noclu3 is offline
Old 18-12-2007   #8
jug
blessed are the apostates
jug's Avatar
Trader Rating: (1)
jug has donated! United Kingdom
you can regularly add redex style detergents, or you can use super unleaded (it works out cheaper and more effective using redex), both will in theory lead to cleaner valves. in practice the effect it has is negligible because both redex and super unleaded additives are really just 95% paraffin. that paraffin can help to clean your injectors as it passes through them, but in the very dilute amount it wont really help significantly. it will clean the inlet valves as the fuel injector sprays pretty much on to the valve, but they are clean on that inlet side anyway because they are closed during combustion. it wont have any effect on your exhaust valves since the paraffin is combusted in the cylinder before it passes through the exhaust valve. the theory is that on the compression stoke both valves will be closed and the cylinder will then have high pressure paraffin cleaning on the inside of both valves. in reality this doesn’t happen because it takes a lot more than a millisecond for paraffin to dissolve the carbon so it can be burnt, and the paraffin will be very diluted even if it did have more time to act.
to overcome the ineffectiveness of fuel additives you can give your valves a proper clean. remove the sparkplugs and pour some (15ml) redex in each cylinder, then turn the engine over for 30 secs. now your valves are covered in paraffin, which dissolves the carbon deposits. wait 5 mins to allow that to happen, then refit the sparkplugs and fire it up so you can burn those carbon deposits off. i do this at every service.
jug is offline
Old 18-12-2007   #9
Trader Rating: (0)
Agree with Jug, a work colleague used to work for Holts-Lloyds as it used to me ,and certainly the old school redex (circa 1990) apparantly was literally nothing more than white spirit, with dye in it, and 'a sort of wax' to thicken it up, so you feel as though you are getting something for your money. c
johnstoke is offline
Old 18-12-2007   #10
Bravo Bravo
jami's Avatar
Trader Rating: (0)
jami has donated! United Kingdom
Dont waste your money, it was completly useless on my hgt
JUG: when you say put it in each cylinder, do you do this by pouring it in the hole where the plug was? Cheers
T 1999 BRAVO HGT 2.0 5CYLINDER 20VALVE - Red Dot Re-map . GSR Induction kit. Sports 200 cell catalyst. Powerflow cat back system. 170BHP 127FT-LB
/\ FOR SALE /\
jami is online now
Old 18-12-2007   #11
Bravo 155 HGT
Trader Rating: (1)
mountainmachine has donated!
where else
mountainmachine is offline
Old 18-12-2007   #12
__________
dave's Avatar
Trader Rating: (10)
dave has donated! Saint Kitts and Nevis
no use redex, use forte or if you cant find that comma do a good one, add to tank
Binki
dave is offline
Old 19-12-2007   #13
Bravo Bravo
jami's Avatar
Trader Rating: (0)
Originally Posted by mountainmachine View Post
where else
Cheeky git Just had to make sure that jug didnt have a super special way of pouring it in
/\ FOR SALE /\
jami is online now
Old 19-12-2007   #14
__________
dave's Avatar
Trader Rating: (10)
i think jug is getting mixed up between fuel additives. and engine additives, a lot of engines additives are chlorinated paraffin
Binki
dave is offline
Old 19-12-2007   #15
Bravo 155 HGT
Trader Rating: (1)
No doubt he has some special piece of hose pipe and a funnel which in turn doubles as his mechanics stethoscope.
He could be, but i think he's talking about using redex to remove the carbon deposits on the valves etc. Most engine additives i've used go in the oil rather than the cylinders.. although granted engine flush for loosening oil and crud from your oil system is mainly kerosene.
Honda MT5 =] unonumero Leisure Lounge 59 15-10-2007 18:59
(G) MK1 Punto Which Engine dom_punto Punto 7 16-06-2006 08:03
tempra engine valves problem kostik4u Tempra 0 05-06-2006 20:47
(T) Uno 999 FIRE ie erratic idle on warm up (Bosch SPI) darren_hill Uno 10 09-04-2005 23:11
