I have a problem with starter not engaging.
The Brava has been garaged for a while (deceased mother's car)
Bought new battery, but when turned key orange key code light comes on then goes off. Thought it might be a coding problem, but found several threads that show that is not the problem. Phew...as I don't have the red key
I am guessing that it might be the starter/solenoid.
Car is automatic so cannot push start.
I will check that it has 12v supply.
If it does can I check by sorting across the starter?
The car had internittent starting problem before being garaged. I saw another thread about the earth lead between the chassis and gearbox being a problem. I will check this out too
Am I going in the right direction with this?
Anyone have any other suggestions about what I could be checking?
Many thanks
Many thanks
