Fiatsimon72
- Oct 16, 2007
- 9
- 5
Hello all!
Injector probs again (!). Have 2000 (W) Bravo 1.6 16v which is causing me problems that are currently doing my head in....... I've read all previous posts regarding injector probs which have given me some ideas of what might be wrong with my motor, but some of the issues with my particular car appear unusual. I'm completely thick when it comes to anything technical, so am relying on a recommended mechanic to be carrying out the cheaper, logical diagnostics first before moving on.
Cutting to the chase ....
If not worth fixing, how much do you fellow fiat people recommend I put Bravo W reg, 67,000 miles, 1.6 16v Trofeo (badged as 100SX, but trofeo on reg doc?) with no MOT, tax etc.
Sorry to be a pain & thanks for all your help.
Simon (previous Punto Active Sport 02 reg owner who wished he had kept it)
- Car hasn't been used for about 9 months, since I was diagnosed with epilepsy and hence banned from driving.
- Failed MOT on emissions 'cos was only running on 3 cylinders.
- Diagnostic test by local garage came up with 'faulty injector'.
- Red faulty injector light illuminated on dash.
- So far the following has been carried out by brother: sparks changed (apparantely in a bad way) & coil changed (was split, I think).
- Recommended mechanic cleaned leads (I think) and reported everything now working.
- MOT retest failed again on emissions as car back on 3 cylinders!.
- I then added a shed load of Redex and filled up with Esso Super and drove the car at decent revs for a couple of hours in the hope of running it back in. After a while, the car stopped misfiring and got above 3000 revs for 1st time since being started after the 9 months. Injector warning light actually went off for a short period also.
- Car back into mechanic, who says car is now running on and off 2, 3 and 4 cylinders!
