Hi, so previously I was having problems and decided to register here for help, however due to email trouble i couldnt complete registration. Anyways I now have fixed on my car what seems to be a fault that is plaguing these forums for so many people and I thought I would shed some light on the situation...
So I bought this Brava 1600 16V Automatic 'V' Registered (99/2000) and got it cheap on the knowing that there was an injector light kept coming on. So I tried the obvious which was run the petrol down then 1/4 fill with optimax and a full bottle of redex and did this twice, but the problem just seemed to get worse! Then the weather started cooling and the light would be on all the time and engine would run terrible mainly on 3/4 cylinders. Then I tried the other 'obvious' thing and took it to a garage and asked for a computer checkup of the engine. I refused on principle to tell the mechanic of the fault as i wanted him to investigate the car thoroughly. He came back with a number 3 injector fault.
So I gave the car to a mechanic whose a friend of our neighbours and he double checked this and said that it definetly was a number 3 injector. What he also tolled me was that the most common fault they are always having with 1600 fiat engines is the injectors are always failing and having to be repaired. He said it was a common fault just on these engines. Anyway, a full strip down of the manifold and £280 quid later I get the car back and its as sound as a pound! This even fixed the irratic idle problems I was having as well So the bottom line I would say to the never ending posts coming up is this;
If you are having problems with an injector light and having bad performance/irratic engine behaviour on a 1600 fiat brava/o then your most likely looking at a new injector which will require a strip down of the manifold
I hope many read this and find it useful in solving their engine problems Puballday
