Ok here goes......
My wifes fiat still wont start. Turn on the car, it turns over but nothing. The red fuel injector light is also staying on.
Here is what I have done so far......
1. Checked power to Ignition coil OK
2. Changed Ignition Coil
3. Changed HT leads
4. Changed Crank Sensor
5. Changed MAP sensor
All it will do is turn over. I have removed one of the plugs after turning it over, and the plug is bone dry.
When you turn on ignition, you can hear the fuel pump kick in and prime the system.
I have also.....
1. Checked the main fuses - 30 - 45 and 80 amps (think they are the right ones)
2. Checked the 2 15 amp fuses next to the red and black relays on the bulk
head
3. Checked the 2 relays ( I think) I unplugged them while car was turned on and got clicking noise as i unplugged them.
It just seems to be now that no fuel is getting into the spark plug chambers, what else could cause the injectors (i guess) not to work
3. Changed HT leads
I have also.....
head
