Hi All,
Having been a Brava owner now for 5 weeks everything was running smoothly until the car cut out and would not restart for approx 10 minutes.
(This has happened a total of 4 times in four days now)
With the help your excellent forum, I believe the first port of call is the Crank sensor, only problem is, I cant find it.
From what I have read the position is the driver side front of the engine bay, and it should be pretty easy to remove. But the only 'sensor' I have found seems to be located under the timing belt cover, and under the cog holding the belt, which looks seemingly impossible to remove!!!
Is this the crank sensor?
Could somebody direct me to the right position?
Any help would be really appreciated
Cheers all
Simon
Cheers all
Simon
