Technical hgt coil packs and ht lead question
Milton Keynes
If I was to go down to my local motor factors and get myself 5 coil packs for my hgt would those mini ht leads come with in the pack or do they come separately? Thanks (y)
there are no mini HT leads, i think you're getting confused with a twinspark alfa :D
on the HGT the coil pack connects directly to the plug.
What are those short rubber things which connect to the top of the spark plug and go up to the coil pack? I thought these were the mini ht lead things?! So as you (jug) say that the coil just connects directly to the plug Im guessing its all one item, so I dont have to buy two separate items i.e coil packs and ht leads?! :confused: (y)
the "short rubber things" are plug holders and insulators. they make sure the current can only pass throught the plug and not arc direct to the head. your coil pack will come with this part fitted, it isnt removable.
