jacko-27
All reply's are welcome but i know jug knows everything about bravo's so here goes.
Car - 99 1.6 16v bravo.
Problem 1 - It struggles starting from cold. After i turn the key the revs idle erratically for a couple of seconds and then rests at the normal idle. If i give it a few revs just as i turn the key everything is ok but i don't like doing this as the engine is still cold.
A few days ago i had it up on a hydraulic lift to check underneath the car and for a few start-ups afterwards it started up perfectly but now it's got worse than before, as if not enough fuel is flowing or the auto-choke is taking a few seconds to adjust. Could it be a sensor?
Problem 2 - Don't know if this is anything to do with problem 1 but the first few times i accelerate in 1st gear from start-up the car judders. Every other gear is ok and it's only the first couple of times i accelerate that it judders. Is it the clutch or some clutch components going?
Last but not least, is changing the sump on a bravo easy, and what's the best gasket/sealant to use?
As always any reply's are welcome, thanks.
