Had a brief look last night at the Coupe wheels & Tyres. All look good with plenty of meat left on the rubber. But I don't think it's possible to fit them directly to a Bravo, without changing the tyres to a small size for the Bravo rolling radius.
The Bravo runs: 185/55 r15 (standard), The Coupe runs: 205/50 r16 (standard). So it would knock the rolling radius out by fitting the Coupe rims with the standard Coupe size tyres on. What you'd really need would be the Coupe rims, but running something like: 195/45 r16. That way you'd have the correct rolling radius.
Accoring to the Miata tyre size calculator just swapping, without chaing the rubber on the Coupe rims, would knock the Bravo speedo out by 4.6%. And at an indicated 60mph, I'd be travelling at 62.8mph.
I guess it depends on how much the standard speedo over-reads on standard rims, would this just then make the speedo actually more accurate?
And, probably more importantly, would 205/50 r16 rubber fit. Or would their be some rubbing somewhere? To me the Bravo arches look pretty big over the 185/55 r15 set up as standard.
