Hi Folks Bought a month ago started off by cutting out. Inj. warning light comes on & engine stops (usually only minutes between faults), changed fuel filter, and looked at fuel tank sender etc. still same. Found this forum searched posts and then came across ECU's:bang: had a local garage do diagnostic tests, for free 1st to clear faults 2nd came up with EGR valve + rail pressure monitor malfunc. but couldn't help further and suggested Fiat Inverness who traced fault to pressure reg on pump. (connectors loose!) £116 for 2hrs & said they fixed it, not so, journey home same fault but def. not so freq. (come back they said!) The fault now happens after a few seconds so not drivable I had booked to go back to Fiat, its 2hrs away, any one got any pointers, not very mechanical, but is it worth stripping down pressure reg. valve, I have a diagram. Or can any of this electronics be safely disconnected and allow me to drive
