General fiat bravo 1.8 hlx remote central locking problems
pink.bravo.hlx.
notts
i have a fiat bravo 1.8i hlx R reg i have all the keys with it and it was remote central locking.:) the problem occurred 2 weeks ago, for either of the following 2 reasons:
1) the interior light which i believe receives the signal from the key fob with the button has been changed as the one i had was faulty:mad:.
or
2) 2 of my family members (children) where messing about with the outside handles and the inside locks:mad:.
the reason i cant figure out which one caused the problem is because both things happened in the same day.
the doors still lock with the turn of the key but the button on the key does nothing and the alarm is not working either.
my partner has check all the following possibility's
fuses, and batteries in the keys what else could it be?:confused::confused::confused:
i will be very very great full for any advice anyone has thank you
regards:eek::eek::eek:
check the new light that was fitted, it must have the 2 ultrasonic sensors and the small button. if it does not you've fitted a light from a car that did not have central locking, so there's no receiver in it.
