chiefster1976
Hi...New to the site..Firstly i will say hi to all....
These sites are so helpful as was for my last car (leon cupra) on the seat web site....
This diesel is just a run about while my Mazda BOngo conversion is completed into a full blown camper..
Anyway enough of that...
I have various little niggles with the recent purchase..
1. Need two door handles...both disintergrated..( which boso decided to make them out of rubber)
2. No rear wiper and Motor not working or washer...
3. after starting engine glow plug light flashes 30 secs then goes out...
4.Need a new plastic door window switch....Not the electrical gubbins. the plastic switch has broke its clips...
5.. sunroof has slight rust on inside and you can hear the wind when its closed...Its hard to tell the stopping point between the tilt and slide to know its fully shut...
My questions im really bothered about is..
1 Do i need to change the glow plugs bearing in mind the flashing light/mileage?
2.. There are TWO types of wiper arms on ebay...One with a push fit type and one with abolt on type....Which is it? Mine is 99v TD sX theres a bolt directly left on the car on a U shape peice left over....
3. I dont have the manual to check wether to change cam belt/ tensioner etc..
4.Should i change the fuel filter? Its running fine by the way..
5Lastly....I have some DEZENT alloys new which i got for a fiesta which i had for a month but never fitted them.....
Apparently they will go on Vaux. PUGS, fords....BUT will they go on my FIAT????
Thanks for your advice, chiefster.....In LEEDS...:slayer:
