as said you have bolts that go up to the wing / bumper join. you have to remove the arch liners and use a long extension bar on the ratchet
as said again, the welded bolt on the wing is shocking,the welding gives up very easily, give them a good dose of wd40 and have the mole grips at the ready. you have to go from under the bonnet to use the mole grips btw
