roseyp
- Dec 11, 2006
- 13
- 6
Hi all,
My bravo 1.4s has developed a rear light problem. Today it was noticed that when you press the brake pedal the rear lights go mental, the rear fog lights, reverse lamps etc all flash in different times and then some stop on.
I suspect an earth fault or corrosion on the tracks of the rear assembly, but ......... is this a common bravo problem with a common cause ??? just to save time in the morning lookng for earth points etc
Roseyp
Roseyp
