they arent even similar.
a MAF sensor is a "hot wire" sensor. a constant voltage is applied to the wire (often called the film). the wire is positioned in the air flow (usually a sampling channel or chamber in the inlet pipe). the current passing through the wire heats it up. as air flows across it, it cools down. the wire is basically just a positive temperature coefficient resistor. its resistance drops when its temperature drops. the drop in resistance allows more current to flow through it (this maintains the temperature of the wire). the current change affects the voltage signal returning to the ecu. this voltage is interpreted as air flow by the ecu. air temperature and humidity are taken into consideration since they also affect the temperature of the wire. this sensor will be affected by air temperature and density so i personally think its the better method to measure mass air flow.
a MAP sensor is completely different. it simply compares the pressure difference between 2 chambers. one chamber is sealed and used as the reference pressure (usually a vacuum) and the other chamber is connected to the intake manifold (usually by a vacuum hose). when the pressure in the intake manifold changes, this will change the voltage signal going back to the ecu from the MAP. a pressure drop will cause a voltage drop. this voltage is only interpreted as manifold pressure. the ecu will also need to use the signals from the rpm sensor and air temp sensor to calculate air mass, pressure alone is not enough. plus any vacuum leaks on the hose, or indeed any other vacuum leaks on the manifold, will affect this sensor's signal, for that reason i think its not a good way to calculate mass air flow.
