Hi There all you guys! I'm a new member just fresh as milk but I have been following your forum for quite some months now.
I'm from Malta and have a 1.8 GT bravo 96'. Had it since new and i love the damn machine!! Will bullet point the history of the progress of my findings after I explain my problem.
Car runs perfectly when cold (automatic Choke).
Car goes from 500 to 1500 RPM when idling for some time at normalrunning temperature.
Cleaned MAF sensor and then replaced with a used one. Problem still there.
Cleaned idle stabilizer valve and then replaced with a used one. Problem still there.
Replaced plugs (wet with rich mixture) with new ones. Problem still there.
Cleaned lambda sensor and read further into the Zirconia Lambda sensor.
0v lean - 0.5v good mixture (14.7:1) - 0.9v rich : So I stuck the mutimeter onto the dash and a cable running to the sensor wires. Sensor heater fine too.
So the machine runs fine when warm: pressing the accellerator on gear 0.8v, releasing the accellerator on gear (engine brake) ecu cuts the fuel altogether and reads 0v.
Return soon after to idling 0.5v. (perfect) Till you leave it on idle for some seconds, say 5 to 10 seconds and voltage starts to increase slowly to 0.9v Richening the mixture like hell.
I can also make a cicuit for this with a bar graph of leds so I can observe better but I can handle the multimeter.
Sh#t I DO NEED HELP!
Love you all
Love you all
