KRB
Hey all,
I have seen many posts relating to problems starting, but nothing that resembles my problem, therefore I have started a new thread in the hope that you can help as I have a Major problem with my car starting / not starting.....
Right, problem is that sometimes it doesnt start but I cant pin it down to anything as it's so inconsistent. For instance, it will start fine in the morning, I will drive it for a little while fine. Then when I try to start it again an hour later (or less) it doesnt start. It will turn over fine (new battery and leads and plugs) but doesnt want to fire up?
When it does this (after trying to start it loads of times), I can literally leave it for 1/2 an hour or so, come back to it and most times it starts fine:bang:
I called the AA out last week becasue after 9 attempts to start it ( it kept failing) I thought they could help. They arrived 45 minutes later and it started first time..no problems!!!
I am told it could be the ignition barrel (or something - sorry non technical) as it may not be reading the key, although I have tried the RED key on many occasions when this happens...doesnt help!
The key doesnt turn freely in the ignition (sticks a bit) so it may be that?
Any help would be greatly appreciated so I can get my baby back on the road with no problems
Keith.
Keith.
