let me guess,you are adding 10 to the power of 20,000bhp with an ebay resistor? :chin:
Do you know where to plug that resistor? I want to know where I plug it please
Thank you
Thank you
i could but its very rude.
read the 20bhp link in my sig
it plugs in the cable that was pluged in nr 5 right?
yes, the temp sensor (number 5) has 2 wires that both go to the ecu.
you should chop one of these wires, and then add the resistor to it.
this will increase the overall resistace of the circuit, making the ecu think the air is cooler.
the ecu will then increase fueling and advance ignition, giving slightly better performance.
if you arent sure which wire to cut ( i think there are 4 on the conector ) check a haynes manual wiring diagram
exactly how would you think you would do it without?
Did you even read the link in custard's sig? :bang:Can anyone tell me if it is really necessary to cut cables?
its built into the throttle case, the following pic shows it clearly.
there is only 1 way to install a resisitor that will give a benefit and maintian the car's varying temp signal, that is to wire it up in series to the temp sensor.
the connector on the top of the throttle case has 2 wires for the temp sensor (and other wires for other things), chop either of these 2 and add the resistor inline with the wire. i'm not sure which 2 wire colours are the 2 wires for the temp sensor, so use a bit of detective work
