Comment
Guide Tools
<!-- google_ad_section_start -->Change Pollen / Cabin Filter<!-- google_ad_section_end -->
service item - SHOULD be 15 min job.
Published by varesecrazy
28-05-2017
Difficulty Level: 2
User Rated:Unrated
Access
I discovered the filter whilst accessing the wiper motor..
it was filthy..so tapped out worst of the ditritis, and sourced a replacement
thanks to MODERN Bravo owner @gadge for supplying one at a good price
Lift the bonnet, use the prop in it's secured position.
walk along the LEFT wing until the Black scuttle drain is in front of you,
the access panel is secured with 2 x self-tapper screws,
and then has 3 x location slots cast into the plastic
remove the 2 x screws
( the panel is then "free")
get a flat screwdriver under the rubber screen to bonnet trim - work/slide it along so that the TOP of the access panel is exposed
tilt the top of the panel FORWARD - away from the screen,
then LIFT the panel out of the 3 x retaining slots
[ATTACH]
Likes gadge liked this post
Contents
<< <    Next Page: Removing filter (Page 1 of 5)    >  >>
Comment
Guide Tools
(T) Pollen - Cabin Filter Goudrons Panda (2012+) 9 02-01-2017 16:30
(T) cabin / pollen filter sheilajean Ulysse 1 15-07-2016 15:14
(G) Cabin/Pollen filter change Fiat Panda 1.2 dynamic eco DTanner Panda 3 17-09-2015 23:24
(T) Dashboard / Pollen filter / Cabin filter / Cluster navan_stilo Stilo 1 01-04-2011 17:02
CABIN/POLLEN FILTER Ady FIAT Boo Archives 4 15-01-2005 15:37
