Blue & Me - Tech Info and questions and answers
Another question: When you turn the ignition on, the media player is often paused. How can you get it to play without voice commands?
Hi, as there are 48 pages in this topic i did read no more than the first 10 :) and did not see my problen/question.
Is it possible to coupple more than 1 phone to Blue me? Thanks in advance
Hi, There should be no problem I don't think pairing up as many as you like but the problem would arise if both phones were in the car at the same time I would suspect......the phone is actually only linked up with the cars blueme after pairing and when switched on and in close vicinity of the car with ignition ON.................I have had blueme TomToms with multiple phones and ipads etc still paired up with the car...some no doubt from old owners......this is why I always advise to go through the process of DELETE ALL clean everything out and just pair up freshly the devices you want
Bye
Ok. The 5.6 is the last supported on your car.
Did you try directly to update to 5.6 ?
Fat32 should be good, did you try with another stick ?
I updated the software, but since then I have another problem.why doesn't the usb player go to the next music? repeat is not turned on
