| | #451 | |||||
| Re: Blue & Me - Tech Info and questions and answers
| | #452 | ||
| Re: Blue & Me - Tech Info and questions and answers I'm having a couple of issues with my B&M: 1. The system recognizes and plays music from the MP3-player/USB stick. BUT I can't browse through the songs (the up/down-buttons don't respond). Also I can't access the menu (no response from the menu-button either). Note that these functions/buttons work fine when I play audio- and mp3-cd's and use the radio. 2. The Windows-button doesn't work at all. Maybe these problems are related to each other, I don't know. Has anyone else had these problems? If so what have you done to fix them? P.s. I've contacted my FIAT-dealer but they don't have time to have a look at the car until next month.
__________________ -------------------------------- >>>> Fiat 500 1.2 Lounge <<<< | |||
| | #453 | |||
| Animal | Re: Blue & Me - Tech Info and questions and answers
Sounds like you need to reset the system, quickest and easiest way is just undo the neg batt terminal and leave disconnected for 5 mins and then refit, and all your blue and me ill's should be cured.
__________________ Gotta love the INTERSCOPE system! | |||
| The following user says "Thank You!" to Omad for this useful post: | ||
martin.j (23-07-2008) | ||
| | #454 | ||
| Re: Blue & Me - Tech Info and questions and answers Battery terminal? What and where is that? Could you explain a bit moore to a noob like me? I'm sorry, my English isn't perfect.
| | #455 | ||
| TJet powaaaaaaa | Re: Blue & Me - Tech Info and questions and answers On the battery in the engine bay, Take off the negative battery terminal(the black one) for 5 minutes and then reconnect it.
__________________ | ||
| The following user says "Thank You!" to punto_matt for this useful post: | ||
| | #456 | ||
| | #457 | ||
| Re: Blue & Me - Tech Info and questions and answers It worked perfectly! Thanks again for the advice!
| | #458 | ||
| Straight outta H-ton! | Re: Blue & Me - Tech Info and questions and answers I took mine into a dealer today because My bluetooth is showing the "no english" error and I can't access the menus, etc. After keeping it all day, they say they need to order a part - a conversion kit - and can't fix the Blue&me unitil it arrives. This all stemmed from when I had a flat battery (I think). Dealer being daft? | ||
| | #459 | |||||
| Red all over the land | Re: Blue & Me - Tech Info and questions and answers
1. pair your phone (when paired it will ask if you want to download your contacts), this will fail and the system tells you how to do it manually. 2. Which leads on to the answer to your question.... scroll through the Blue & Me menu until you see "Settings", then select, scroll through to "add contacts", this is where you need to use your phone menu. 3. On your phone go to "contacts" and select "mark all", then in "options" (usually bottom left) scroll through to "send buisness card", select this then "send via bluetooth", your phone will search for devices , once it has found B&M press "send", this should send all your contacts from your phone to your B&M system, once they have sent (you hear clicks for every contact being sent Sorry if this is a bit long winded but it does work honest.
| | #460 | ||
| TJet powaaaaaaa | Re: Blue & Me - Tech Info and questions and answers Worked for me when i had my N95 aswell ![]()
| | #461 | ||
| Re: Blue & Me - Tech Info and questions and answers ive just got a 1.9 sporting and i'm getting to grips with the blue & me, so far so ggod. but how do i get the message reader to work? i've got an ericsson w880i
| | #462 | ||
| Re: Blue & Me - Tech Info and questions and answers ....its ok ive read earlier posts and followed the instructions - works spot on! cheers
| | #463 | ||
| Re: Blue & Me - Tech Info and questions and answers I'm using my iPhone in my 500, and it works (almost) fine - I can use the Blue & Me etc. However, and this is quite odd - I can't charge my phone through the USB port (although I can charge my iPod there). Any thoughts? thanks, yariv
| | #464 | ||
| Re: Blue & Me - Tech Info and questions and answers heya , does any1 have a different ring tone in their car from the original ? if so pm me please because it is so annoying thank you james
| | #465 | ||
| Re: Blue & Me - Tech Info and questions and answers hello, my blue&me device doesn't recognize any voice commands. What can I do to fix it? thanks
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| VO2Max |
