The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > Blue and Me
Old 18-07-2008   #1
col-blue's Avatar
Trader Rating: (0)
USB Hard Drives
Will drives like this work with Blue & Me http://www.argos.co.uk/static/Produc...%7C9555963.htm
Orange 1.9 Grande Sporting
col-blue is offline
Old 18-07-2008   #2
Panda Powered Squirrel
udtrev's Avatar
Trader Rating: (0)
udtrev has donated! United Kingdom
Talking Re: USB Hard Drives
You may need to buy a current invertor to run it, it's likely that it has a separate power supply !!
And now tip time, if the power supply dies or the interface does, you can take the HD out and put it in your pc on a dedicated IDE cable
Unfortunately I am saying that from experience - cheers Toshiba
Originally Posted by rallycinq View Post
A wee bit of lubrication before you shove it in (saves chafing, apparently)
udtrev is offline
Old 18-07-2008   #3
Symmetry
Trader Rating: (0)
Adrian_Bravo_96 has donated! United Kingdom
Re: USB Hard Drives
No it will not work
For a 2.5" external laptop drive you need 2x USB ports to power it.
For a 3.5" you need 1x USB port but you also need a mains power supply.
Blue and me only has 1x USB slot so you can only use a USB flash drive.
You could buy a 16GB, 32GB, or even a 64GB USB flash drive.
Wanted: passenger front wing for My Bravo. Colour code 387/A
Wanted: passenger door card for a 387/A
Adrian_Bravo_96 is offline
Old 19-07-2008   #4
Fat pigeon... APPLE!
JonnyBoy's Avatar
Trader Rating: (1)
JonnyBoy has donated! United Kingdom
Re: USB Hard Drives
Seems odd that the B&M USB port has such a gutless power supply.
I tried a USB 2.5" HDD that runs perfectly happily off a single USB port on any laptop or PC, and the B&M wouldn't power it, the drive light came on but it just sat and went "click... click... click... ".
Has anyone found a particular make/model of USB HDD that consumes small enough currents for the B&M port to power it?
Then: mildly-modded Punto 55SX; rusty Ford Capri 2.0 Laser
Now: mk2 Focus Zetec Ti-VCT; same Capri, less rust
Soon: Bravo Dynamic 150 MJet, in red, with extra toys
JonnyBoy is offline
Old 19-07-2008   #5
udtrev's Avatar
Trader Rating: (0)
Could you not buy a 12v invertor and run the drive from that ? (assuming you have a ciggie lighter socket)
udtrev is offline
Old 26-07-2008   #6
Trader Rating: (0)
Re: USB Hard Drives
I got it to work with a laptop HDD once - see my post on this in this thread
http://www.fiatforum.com/bravo/15451...isk-error.html
i don't recommend it though, more bother than it was worth.
MaffC
His - Techno Grey Bravo Sport 1.4 T-Jet 150
Hers - Chemical Grey Grande Punto Active 1.2
maffc is offline
Old 01-08-2008   #7
zygote's Avatar
Trader Rating: (0)
Re: USB Hard Drives
Have a look at my post on Alfaowner, "http://www.alfaowner.com/Forum/ice-and-blue-and-me/116645-hdd-working-in-blue-and-me.html"
Basically, 1.8" hard drives should work fine. Mine does and has given me no problems whatsoever.
P.S. no direct link because apparently I'm not allowed to post URL's until I have at least 5 posts, even if I'm trying to help people! Jeez mods, lighten up!
zygote is offline
Old 03-08-2008   #8
Trader Rating: (0)
Re: USB Hard Drives
i will be geting a invortor for my hdd and just keeping it in the car with all my music on no problems
mily260 is offline
vB code is On
USB device drivers - why do they need reinstalling if a different USB port is used? JonnyBoy Computing 9 13-12-2007 14:23
hard drives and cable colouring andywilson86 Grande Punto > Technical 1 15-05-2007 09:02
Bootable USB hard drive? Hellcat Computing 3 19-11-2006 15:57
bloody crappy laptop hard drives arc Computing 5 19-11-2006 10:43
Computer problems - hard drives and graphics cards JonnyBoy Leisure Lounge 2 18-10-2005 15:34
