| A Blue & Me Intermittent Fault Really dont know how to deal with this the fault happens so randomly its impossible to tell if / when its going to do it next, but when it does happen its very very annoying and lasts for hours if on the phone or listening to my MP3 player the front driverside door speaker will crackle like f*ck louder than the music / phone call and in some cases cut out leaving only the left side and rear speakers working which is annoying, more often than not on the phone it will interfere with the turbo and you can hear it really high pitched whistling through the speaker :lol: when its crackling and cutting out if I flick it to the radio or CD its fine, no problems at all, so the problem is within the Blue And Me System
| Re: A Blue & Me Intermittent Fault No One?
| | #3 | ||
| Forum Moderator | Re: A Blue & Me Intermittent Fault
| | #4 | ||
| Re: A Blue & Me Intermittent Fault Yo, Not sure if this will help you out but there is one theory I can think of.... You say it only does it when using the blue and me system right, my first question is where in the car do you keep your phone because my thought is that if there is any exposed wire ( none Insulated ) on the back of the speaker then it could be possible that your phones signal is causing an intermittent carrier signal through your speaker transducer, this can in some cases cause a spark which would earth out which could cause the speaker to black out for short periods of time, On the other hand you might have had the apprentice build your car lol Bit of a guess chap but at least it's a thought. cheers Bravo08 ![]()
| | #5 | ||
| Re: A Blue & Me Intermittent Fault Lol didnt even know this section exsisted, that could be the problem, next time il chuck the fone in the boot or summat :lol:
| Steering - Intermittent fault | paulbrook | Punto | 1 | 26-02-2008 13:29 |
| Bravo intermittent starting fault | Nigmyk | Bravo / Brava | 4 | 03-09-2007 11:52 |
| Intermittent Airbag Fault | FiatStilo02 | Stilo > Technical | 13 | 27-05-2007 13:14 |
| Intermittent Radio Fault | TC290871 | Stilo > Technical | 6 | 24-08-2006 12:17 |
