Considerations:
High voltage – make sure you do not touch any part of the kit while it has a live feed!
The manufacturers instructions (in respect to the wiring) are correct and easy to use – read them first and don’t take my word for it!!!
When drilling the holes I suggest drilling a pilot hole first then chasing out with the correct sized drill bit
Take your time – drilling the holes can be awkward – don’t rush it!
You will need to drill through your B so make sure you cover any holes with paint to inhibit rust otherwise your car will disintegrate when it rains
Its and easy mod – take your time drilling the holes and make sure you leave enough room for the bracket fittings before going wild with power tools. Should take no more than 3 hours to do both sides………
