Stilo Connect Nav+ Unit
Is it worth buyin a Connect Nav+ unit for a 1.6 stilo? i mean the hastle of installing it and finding the extra fittings to make it work?
Entirely up to you; I'm installing it into my 1.8 Dynamic. So far the unit is in, wiring is almost done; all I need to get is the antenna and microphone then I'm done :)
Bear in mind, the extras from FIAT will cost around £200 (GPS/GSM Antenna is £150, Microphone is £42, Cage is £8), you need to drop the roof lining to fit the antenna, and adapt the standard wiring to have a timed ignition feed. This is the second Stilo we (me and my bro :p) have done so we're getting good at it :D
