FIAT Auto Specialist Team
Thread Tools
Old 16-06-2017   #1
The rare car hunter
onemanmade's Avatar
onemanmade has donated!
ANOTHER Fiat Panda Parade L516 JSC Auction 99p Start
http://www.ebay.co.uk/itm/fiat-panda...%257Ciid%253A1
Two Parades for sale at once right now on ebay! Unusual for such a rare model. Its another one which hasnt been on the forum before too! This time in the Danish Blue (or Purple as its otherwise known)
Hasnt been papped on flickr either
Ad reads as follows: fiat panda parade for spares or repair needs welding to the floor inner sills.damage to rear bumper. runs and drives.no reserve need space. cash on collection only.
This one MUST be worth saving for somebody, lovely twin sunnies motoring. A wee bit of love required is all I reckon
Test date28 February 2013 Expiry date1 March 2014 Test ResultPass Odometer reading56,895 miles MOT test number3292 3995 3096
Test date24 February 2012 Expiry date1 March 2013 Test ResultPass Odometer reading55,285 miles MOT test number2995 1545 2066
Test date21 February 2012 Test ResultFail Odometer reading55,282 miles MOT test number7595 4245 2081 Reason(s) for failure
Offside Seat belt anchorage prescribed area is excessively corroded (5.2.6)
Nearside Seat belt anchorage prescribed area is excessively corroded (5.2.6)
Nearside Body has a sharp edge caused by corrosion (6.1.C.1)
Rear Body has a sharp edge caused by damage (6.1.C.1)
Fuel cap/sealing device sealing washer missing (7.2.4c)
Horn not working (1.6.2a)
Windscreen washer provides insufficient washer liquid (8.2.3)
Nearside Obligatory mirror insecure (8.1.1)
Test date25 February 2011 Expiry date1 March 2012 Test ResultPass Odometer reading53,956 miles MOT test number6957 7665 1040 Advisory notice item(s)
slight play n/s/r and o/s/r top shocker bushes
Test date23 February 2011 Test ResultFail Odometer reading53,953 miles MOT test number1179 0455 1474 Reason(s) for failure
Nearside Windscreen washer provides insufficient washer liquid (8.2.3)
Test date2 March 2010 Expiry date1 March 2011 Test ResultPass Odometer reading53,004 miles MOT test number2928 4126 0091
Test date24 February 2010 Test ResultFail Odometer reading53,000 miles MOT test number1738 5525 0462 Reason(s) for failure
Nearside Front Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Offside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Offside Front Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Rear Exhaust has a major leak of exhaust gases (7.1.2)
Front Headlamp not working on main beam (1.7.5a)
Exhaust emissions Lambda reading after 2nd fast idle outside specified limits (7.3.D.3)
Test date26 February 2009 Expiry date25 February 2010 Test ResultPass Odometer reading52,158 miles MOT test number3104 9795 9058
Test date24 February 2009 Test ResultFail Odometer reading52,155 miles MOT test number5934 5555 9015 Reason(s) for failure
Offside Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Offside Rear fog lamp not working (1.3.2b)
Offside Front Tyre worn close to the legal limit (4.1.E.1)
Test date21 February 2008 Expiry date20 February 2009 Test ResultPass Odometer reading51,670 miles MOT test number6636 7285 8078
Test date20 February 2008 Test ResultFail Odometer reading51,666 miles MOT test number5647 6185 8091 Reason(s) for failure
Offside Front constant velocity joint gaiter split (2.5.C.1a)
Test date16 February 2007 Expiry date15 February 2008 Test ResultPass Odometer reading49,442 miles MOT test number1412 8704 7486 Advisory notice item(s)
Test date27 April 2006 Expiry date26 April 2007 Test ResultPass Odometer reading47,959 miles MOT test number2520 7731 6151 Advisory notice item(s)
Nearside Front Brake hose slightly deteriorated (3.6.B.4d)
Nearside Front Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
offside front tyre wear 2.mm legal limit 1.6mm
offside front inner wheel rim slight dent
Test date21 April 2006 Test ResultFail Odometer reading47,932 miles MOT test number2644 0141 6196 Reason(s) for failure
Nearside Stop lamp not working (1.2.1b)
Offside Stop lamp not working (1.2.1b)
Nearside Rear position lamp(s) excessively deteriorated so that it is not visible from a reasonable distance (1.1.A.3d)
Nearside Vehicle structure is cracked, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
Offside Vehicle structure has an unsatisfactory modification, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
onemanmade is offline Reply With Quote Quote
Old 3 Weeks Ago   #2
Aim for 100%, accept 95%
Pandani's Avatar
Pandani has donated!
Re: ANOTHER Fiat Panda Parade L516 JSC Auction 99p Start
Didn't sell, hope it still went to a good home as it's definitely worth saving.
With the occasional good days of sunshine we're having at the moment, I sometimes wish I'd twin sunnies on Pandani especially as she's only going to be taxed for the best six months of the year.
Corroded door bottoms.......the hallmark of a genuine Panda.
'90 Panda 1000CL,'05 Punto 1.2 8v,'10 Alfa Mito 1.4 135
Pandani is offline Reply With Quote Quote
Thread Tools
Panda (Classic) Panda CLX project 99p start. Liquid Knight Auction Watch 9 24-06-2012 00:28
13" 6J Minilite style Fiat fitment wheel 99p start J333EVO Auction Watch 3 13-03-2007 10:01
