Complete lack of detail in the ad is infuriating, must have been painted at some point to be that shiny complete with dented quarter panel.
Wouldn't kick it off the drive though!
Cant stand tixuz website, the photo`s dont show if you use Google Chrome browser (not that this ad has pics), & the numbers seem to be `security` phone numbers.
Mk1 fiat panda, white 903cc, 1984, mot 10 months, good solid condition. many new parts. New alternator, starter motor, water pump, 48,354 miles. Spent its life in Guernsey up until 1999. 5 0wners.
Reason(s) for failure
Nearside Headlamp aim too far to the right (1.8)
Exhaust emissions carbon monoxide content excessive (7.3.B.1a)
Service brake: efficiency below requirements (3.7.B.7)
Nearside rear parking brake recording little or no effort (3.7.B.6a)
Advisory notice item(s)
Parking brake: parking brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.7)
Test date 9 May 2013
Expiry date 8 May 2014
Test Result Pass
Odometer reading 48,331 miles
MOT test number 8260 5982 3146
off side front shocker spacer broken
Test date 19 March 2013
Test Result Fail
MOT test number 6298 0857 3097
Nearside Front Statutory seat belt missing (5.1.1)
Offside Indicator tell tale inoperative (1.4.A.2a)
Offside Front Direction indicator not working (1.4.A.2c)
Nearside front brake binding (3.7.B.1)
Brakes imbalanced across an axle (3.7.B.5b)
Service brake: service brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.7)
brake warning light on
Test date 8 December 2011
Expiry date 7 December 2012
Test Result Pass
Odometer reading 48,248 miles
MOT test number 4987 7264 1437
Nearside Front Macpherson strut has slight movement at the upper attachment (2.5.A.1c)
Offside Front Macpherson strut has slight movement at the upper attachment (2.5.A.1c)
Rear Brake hose slightly deteriorated (3.6.B.4d)
Test date 7 December 2011
Test Result Fail
MOT test number 4558 1104 1373
Windscreen washer provides insufficient washer liquid (8.2.3)
Exhaust has part of the system excessively deteriorated (7.1.1a)
Exhaust has a major leak of exhaust gases (7.1.2)
Test date 10 November 2011
Test Result Fail
Odometer reading 48,244 miles
MOT test number 4975 9491 1322
Hazard warning switch faulty (1.4.B.1d)
Horn not working (1.6.2a)
Nearside Front Seat belt insecurely fixed to the vehicles structure (5.2.1a)
Offside Rear Tyre has a tear, caused by separation or partial failure of its structure (4.1.D.1b)
Centre Rear Brake hose ferrule excessively corroded (3.6.B.4e)
Nearside Front Macpherson strut insecure (2.4.G.1)
Offside Front Macpherson strut insecure (2.4.G.1)
Nearside Front Lower Suspension arm rubber bush deteriorated resulting in excessive movement (2.4.G.2)
Centre Front Exhaust has a major leak of exhaust gases (7.1.2)
Exhaust noise is clearly in excess of that emitted by a similar vehicle fitted with a standard silencer in average condition (7.1.4)
Spare wheel insecure (6.4.2)
Offside Rear rear brake recording little or no effort (3.7.B.5a)
Nearside Front rear brake application uneven (3.7.B.2)
Offside Front rear brake application uneven (3.7.B.2)
Exhaust engine idle speed too high (7.3.A.2a)
unable to open rear tail gate.
hazard lights not working,
Test date 23 January 2006
Expiry date 22 January 2007
Test Result Pass
Odometer reading 48,069 miles
MOT test number 2425 4362 6099
Test date 20 January 2006
Test Result Fail
MOT test number 4129 7012 6006
Nearside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Nearside Front Vehicle structure has excessive corrosion which adversely affects braking or steering (6.1.A.1)
Nearside Rear Shock absorber has a slightly worn bush (2.7.4)
Offside Rear Shock absorber has a slightly worn bush (2.7.4)
Nearside Rear Shock absorber has slight corrosion to the casing (2.7.2a)
Offside Rear Shock absorber has slight corrosion to the casing (2.7.2a)
Nearside Front Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Offside Front Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Nearside Front Macpherson strut corroded but not seriously weakened (2.4.G.1)
Offside Front Macpherson strut corroded but not seriously weakened (2.4.G.1)
Front Brake pipe slightly corroded (3.6.B.2c)
Rear Brake pipe slightly corroded (3.6.B.2c)
fuel pipes corroded
oil leak
corrosion on fuel tank
