For andyholli (V8 fix) and JamieK (local - ideal runabout..)
http://www.gumtree.com/p/other-car-parts-accessories/4x4-3.5-v8-fiat-panda-/1125635297
If the engine matches the chassis (ie it's a 1972 V8) then it will be lucky to get 14mpg so even with an LPG conversion is still going to cost twice as much to run as standard panda running on petrol, not to mention the huge raft of problems the early V8s suffered from. It's a great toy but certainly not a daily runner.
Just shows how compact the original Range Rovers where and not the ridiculous "sports barge" they are now.
Best bet with that is to tip the v8 in the bin and fit an AMC/Chrysler/Jeep 4.0 six in there. Gutsy, reliable and good on LPG.
Mine had a 3L Isuzu Diesel engine which are cheap to source (usually found in the trooper or Vauxhall Monterey) and there is an adaptor kit to fit them to the ranger over gearbox.
Madness!
You don't hear Rover V8s very often anymore, and I miss them.
- All this talk of installing boat anchor diesels instead of that silken, woofly piece of aluminium loveliness, in order to save a few pence after 15 thousand miles that will take years, if ever, to drive.
More like swap the V8 out because it will have broken, the V8s are as brittle as the alloy they are made from and are renowned for breaking ts the sight of a hill especially once they get old.
On top of this an old worn Range Rover V8 will need an oil change every 3000-5000 miles and trust me they take a hell of a lot of oil, you also need to keep the coolant system in tip top shape with regular coolant changes.
Sling a diesel in and it will last forever.....unless it's the oem Italian VM diesel with 4 individual head gaskets
