Nice looking example
http://www.ebay.co.uk/itm/Fiat-Panda-4x4-Classic/181787016158?_trksid=p2046732.c100040.m2060&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20140107095009%26meid%3D2273b9b0ea334e4abbd84926419e9b03%26pid%3D100040%26rk%3D4%26rkt%3D4%26mehot%3Dpp%26sd%3D331559520953
For Sale I have a very original and unmolested Classic Panda 4x4. It has a genuine mileage of under 48000. We have owned the vehicle since November 1998 and in that time it has covered approximately 10000 miles. It was used by my mother for a run around/shopping car until 2004 when we bought her a Seicento. It was then put into dry storage until this year when I decided to recomission her. In order to pass the MOT test we needed to carry out some minor welding repairs to both rear inner sills, and the carburettor needed a strip and clean to get the emissions correct. The interior trimming is excellent. The gearbox and four wheel drive system is all operational. Bodywork wise it is generally excellent for a 27 year old vehicle with the exception of the n/side front door having corrosion on the lower edge and would benefit from a new doorskin or a second hand door and a slight dent on the o/side rear wheel arch front edge and slight misalignment of the rear bumper. Both of these faults are shown in the pictures. She drives very well and any inspection is welcomed.
Description does match MOT history held by DVLA
Your MOT history
You asked for test history information for vehicle registration E118UOH. You provided test number 769466565190 to confirm that you had a legitimate interest in the vehicle. If you do not have a legitimate interest in the vehicle you must destroy the document. This information is correct at 02/07/2015.
There are no later tests for this Vehicle.
Most Recent Vehicle Details and Test Summary applicable to this test number.
Registration mark:E118UOH
Make/Model:FIAT / PANDA
Colour:WHITE
VIN/Chassis No:ZFA141A00040*****
Approximate date of first use:14/03/1988
Type of fueletrol
Date of test:15/06/2015Certificate issued (Pass)
Odometer reading:47,659 Miles
Test number:7694665*****
Test expiry date:14/06/2016
Full Test History, starting with first recorded vehicle and test results
Date of test:08/06/2015Certificate issue refused (Fail)
Odometer reading:47,651 Miles
Test number:296389255115
Test station name:BIRD AND YATES LIMITED
Test station number:1ALH47
Test station telephone number:01543503885
Test class:IV
Reason(s) for refusal to issue Certificate
Offside Rear inner sill Suspension spring mounting prescribed area is excessively corroded (2.4.A.3)
Advisory Notice issued
Wiper blade split at end
Test number:769466565190
Test class:IVTest expiry date:14/06/2016
No Advisory Notice issued
This completes the test history for the above vehicle as recorded on VOSA's MOT Computerisation Database
Your MOT history
Colour:WHITE
Type of fueletrol
Test class:IV
