Thread Tools
Old 07-05-2014   #1
PANDA!!
Freebo's Avatar
Freebo is part of the official FF Events Team :)
Freebo has donated!
Ghost Ball Champion
Panda 4x4 Sisley [H951 THO]
Quote Quote:
MOT. New tyres, battery, exhaust. Good original example. Family owned since 2000, RED, 1,550 60k
http://www.autotrader.co.uk/classifi...1405053930817/
Freebo is offline Reply With Quote Quote
Old 07-05-2014   #2
PANDA!!
Freebo's Avatar
Freebo has donated!
Ghost Ball Champion
Re: Panda 4x4 Sisley [H951 THO]
Looks quite tidy to me, well worth the money I think
Likes homeward liked this post
Old 07-05-2014   #3
onemanmade has donated!
Bloody good price for that! If it had bullbars and twin sunnies would be perfect
750L Progress thread:https://tinyurl.com/m5ra2gt
1.1 Active Progress Thread: https://tinyurl.com/y86qyray
http://badges.fuelly.com/images/sig-uk/620023.png
onemanmade is offline Reply With Quote Quote
Old 07-05-2014   #4
Just Drive It
JamieK's Avatar
JamieK has donated!
Looks a real bargain to me! It's in the classifieds too
JamieK is offline Reply With Quote Quote
Old 30-01-2017   #5
PANDA!!
Freebo's Avatar
Freebo has donated!
Ghost Ball Champion
www.ebay.co.uk/itm/Fiat-Panda-SISLEY-4X4-/322406752673?hash=item4b10f0a1a1:g:XwsAAOSwA3dYjmU 0
5000
Quote Originally Posted by silverstonecars
Two original keys, Rare panda sisley 4x4, Lots of history,Metallic red, Runs and drives well fun little car. WE OFFER COMPREHENSIVE RAC WARRANTY'S ON ALL CARS -Specialists In Sourcing High Quality Used Cars, 5,000
Quote Originally Posted by MOT HISTORY
Check the MOT history of a vehicle
Registration number: H951THO
  • Vehicle make FIAT
  • Vehicle model PANDA
  • Date first used 8 February 1991
  • Fuel type Petrol
  • Colour Red
MOT history of this vehicle
  • Test date 17 January 2017
  • Expiry date 16 January 2018
  • Test Result Pass
  • Odometer reading 70,942 miles
  • MOT test number 6630 8192 4050
  • Advisory notice item(s)
    Parking brake lever has little reserve travel (3.1.6b)
    Exhaust has a minor leak of exhaust gases slight blow front pipe area (7.1.2)
    nearside rear Rear wheel bearing has slight play (2.6.2)
  • Test date 18 November 2016
  • Test Result Fail
  • Odometer reading 70,939 miles
  • MOT test number 4662 8025 4735
  • Reason(s) for failure
    nearside front Direction indicator not working (1.4.A.2c)
    Exhaust system not adequately supported centre rubber hanger broken (7.1.1)
    nearside front lower Front suspension has excessive play in a lower suspension ball joint (2.5.B.1a)
    nearside front Front suspension retaining device ineffective track arm inner bolt loose (2.5.A.4)
    engine mounting bracket insecure and likely to fail rear gearbox mount (6.1.D.1b)
    Exhaust has a minor leak of exhaust gases slight blow from manifold area (7.1.2)
    offside rear Seat belt anchorage prescribed area is corroded but not considered excessive inner sill under (5.2.6)
    offside rear Rear wheel bearing has slight play (2.6.2)
  • Test date 10 June 2015
  • Expiry date 15 June 2016
  • Test Result Pass
  • Odometer reading 68,910 miles
  • MOT test number 3285 0196 5133
    Nearside Front suspension ball joint dust cover damaged, but preventing the ingress of dirt (2.4.G.2)
  • Test Result Fail
  • MOT test number 8887 2176 5129
    Nearside Headlamp aim beam image obviously incorrect (1.8.A.1b)
    Offside Headlamp aim beam image obviously incorrect (1.8.A.1b)
  • Test date 16 June 2014
  • Expiry date 15 June 2015
  • Test Result Pass
  • Odometer reading 60,334 miles
  • MOT test number 8366 3776 4107
    Nearside Front Brake pipe slightly corroded (3.6.B.2c)
  • Test date 5 June 2014
  • Test Result Fail
  • MOT test number 9360 5605 4150
    Offside Lower Front suspension ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.4.G.2)
    Nearside Track rod end ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.2.C.1c)
    Offside Track rod end ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.2.C.1c)
    Nearside Rear Brake pipe inadequately supported (3.6.B.1)
    rear prop shaft(rear uj) slightly worn
  • Test date 20 August 2013
  • Expiry date 19 August 2014
  • Test Result Pass
  • Odometer reading 60,295 miles
  • MOT test number 2175 6223 3283
    Oil leak
  • Test date 24 July 2013
  • Test Result Fail
  • Odometer reading 60,289 miles
  • MOT test number 6698 1570 3238
    Parking brake: efficiency below requirements (3.7.B.7)
    Fuel pipe leaking (7.2.3)
    Front Exhaust has a major leak of exhaust gases (7.1.2)
    Centre Exhaust system not adequately supported (7.1.1)
    Oil leak
  • Test date 20 August 2012
  • Expiry date 19 August 2013
  • Test Result Pass
  • Odometer reading 60,262 miles
  • MOT test number 5493 2313 2295
    under body condition poor
  • Test date 1 December 2011
  • Test Result Fail
  • Odometer reading 60,243 miles
  • MOT test number 1857 9553 1390
    Nearside Front Direction indicator not working (1.4.A.2c)
    Nearside Headlamp aim too low (1.8)
    Centre Windscreen wiper does not clear the windscreen effectively (8.2.2)
    Front Tyre has ply or cords exposed (4.1.D.1b)
    Offside Front Tyre has ply or cords exposed (4.1.D.1b)
    Nearside Rear Tyre has ply or cords exposed (4.1.D.1b)
    Offside Rear Tyre has ply or cords exposed (4.1.D.1b)
    Nearside Front Tyre has ply or cords exposed (4.1.D.1b)
    Front Brake pipe excessively corroded (3.6.B.2c)
    Offside Front Brake pipe excessively corroded (3.6.B.2c)
    Offside Front Subframe mounting prescribed area is excessively corroded (2.4.A.3)
    Offside Seat belt anchorage prescribed area is excessively corroded (5.2.6)
    Vehicle structure excessively corroded within 30cm of towbar mounting (6.6.6)
    rear brake application uneven (3.7.B.2)
    Nearside front brake binding (3.7.B.1)
    Nearside rear parking brake recording little or no effort (3.7.B.6a)
    Rear Service brake: service brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.7)
Old 30-01-2017   #6
Rollin' On Steelies
AndyPanda4x4's Avatar
Trader Rating: 1
AndyPanda4x4 has donated!
Looks like it's had it's fair share of welding! Bur has it been done to the required 5K Standards
Fiat Panda 4x4 - What the Yorkshire Dales were made for.
AndyPanda4x4 is offline Reply With Quote Quote
Old 30-01-2017   #7
PANDA!!
Freebo's Avatar
Freebo has donated!
Ghost Ball Champion
Quote Originally Posted by AndyPanda4x4 View Post
There was a guy asking about this in the Facebook group a few weeks ago. He felt he got ripped off after buying it from a dealer following seeing how much they bought it for. Looking at the pictures it doesn't seem any thing too special. Certainly not 5k special but may look different in the flesh.
Old 31-01-2017   #8
panda1408 has donated!
Quote Originally Posted by Freebo View Post
He didn't pay anywhere near 5k for it though did he?! He was on about painting it too so it can't be perfect.
1988 Panda 4x4 Sisley
1982 Panda 45
panda1408 is offline Reply With Quote Quote
Old 31-01-2017   #9
PANDA!!
Freebo's Avatar
Freebo has donated!
Ghost Ball Champion
Quote Originally Posted by panda1408 View Post
Yea it wasn't that much. Looking at who's selling it I suspect the guy on Facebook has sold it to a dealer who's trying to make some money.
Old 31-01-2017   #10
It's not the first of April yet is it Possibly its just an advertising ploy.
Sjvarley is offline Reply With Quote Quote
Old 04-02-2017   #11
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Quote Originally Posted by Sjvarley View Post
Start high and drop it low?
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
2 White Classic Panda Selecta's, 1989 Panda 750L,
2013 Toyota Prius Plug-In & 2009 Panda Eleganza
Most Easterly Pandas is offline Reply With Quote Quote
Old 16-05-2017   #12
Here is one that has been mentioned on the forum before, its a Sisley 4x4 H951 THO being sold this time through silverstone car sourcing, Towcester
http://www.ebay.co.uk/itm/Fiat-Panda...sAAOSwA3dYjmU0
Was for sale in May 2014 through Autotrader, and then again in January 2017 according to this thread. For the purposes of keeping all the information together I am posting this in the original thread from 2014 which was updated in January with MOT results etc
Hasnt been papped on flickr
Likes Most Easterly Pandas liked this post
Thread Tools
