Could be anything. Not a helpful advert; with three very uninformative photos.... :bang:
...but pretty sure it says its a Fiat Pamda. Some sort of special model
...especially with only 52 miles.
barbizon1982 said:I am very sad to be parting with my Fiat Panda. It has been professionally modified with a 1.2 litre fiat punto sport engine which combined with its light weight makes it very nippy and a fun run around. Would be perfect for hill climb. Unfortunately it has failed its MOT, requiring welding to the suspension which is beyond my skills to do affordably.
Its recently been on a 2000 mile road trip around the UK with no problems and runs well.
65000 miles
Alloy wheels, new exhaust December 2016. Spare bonnet (white)
Viewing welcome
On 28-Jan-17 at 09:55:57 GMT, seller added the following information:Car based in Exeter area
On 29-Jan-17 at 09:16:00 GMT, seller added the following information:To be clear, the car has failed its MOT and this expires 29/1/17 meaning that this car would have to be trailered away unless driven to an pre-booked MOT at a Testing Station (Subject to having valid insurance cover). I have deliberately not put a buy it now price in and am happy to let the auction run to completion.
MOT HISTORY said:Check the MOT history of a vehicle
Registration number: M578NBE
- Vehicle make FIAT
- Vehicle model PANDA
- Date first used 18 March 1995
- Fuel type Petrol
- Colour Black
MOT history of this vehicle
- Test date 27 January 2017
- Test Result Fail
- Odometer reading 64,972 miles
- MOT test number 1916 8456 5900
- Reason(s) for failure
Windscreen wiper does not clear the windscreen effectively (8.2.2)
Horn not working (1.6.2a)
offside Front position lamp(s) not working (1.1.A.3b)
nearside Headlamp aim beam image obviously incorrect (1.8.A.1b)
nearside front Suspension component mounting prescribed area is excessively corroded by tie bar mount (2.4.A.3)
offside front Suspension component mounting prescribed area is excessively corroded by tie bar mount (2.4.A.3)
nearside rear Suspension component mounting prescribed area is excessively corroded by tie bar mount (2.4.A.3)
offside rear Suspension component mounting prescribed area is excessively corroded by tie bar mount (2.4.A.3)
nearside rear Tie bar/rod rubber bush bonding deteriorated resulting in excessive movement both bushes (2.4.G.2)
offside rear Tie bar/rod rubber bush bonding deteriorated resulting in excessive movement both bushes (2.4.G.2)
- Advisory notice item(s)
front Tyre worn close to the legal limit both sides (4.1.E.1)
- Test date 30 January 2016
- Expiry date 29 January 2017
- Test Result Pass
- Odometer reading 60,349 miles
- MOT test number 8218 4261 9360
- Test date 24 October 2014
- Expiry date 23 October 2015
- Test Result Pass
- Odometer reading 58,932 miles
- MOT test number 3579 2769 4468
Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
n/s/f tyre perished
o/s/f tyre perished
- Test Result Fail
- MOT test number 5357 4709 4231
Offside Front Headlamp aim beam image obviously incorrect (1.8.A.1b)
n/s/f tyre perished
o/s/f tyre perished
- Test date 16 March 2013
- Expiry date 18 March 2014
- Test Result Pass
- Odometer reading 50,518 miles
- MOT test number 1662 9577 3495
Nearside Front Front drive shaft support bearing slightly worn (2.5.C.2c)
Nearside Rear Trailing arm has slight play in a ball joint (2.4.G.2)
Offside Rear Trailing arm has slight play in a pin bearing (2.4.G.2)
Nearside Front Front suspension has slight play in a lower suspension ball joint (2.5.B.1a)
Offside Front Front suspension has slight play in a lower suspension ball joint (2.5.B.1a)
hand brake has slite movement
fuel smell inside the car
n/s/f steering rack boot gaiter slite leak
Oil leak
- Test Result Fail
- MOT test number 1677 8597 3036
Drivers seat fore and aft adjustment mechanism not functioning as intended. (6.2.A.3)
Offside Front Tyre has ply or cords exposed (4.1.D.1b)
Nearside Front Trailing arm rubber bush deteriorated resulting in excessive movement (2.4.G.2)
Offside Front Trailing arm rubber bush deteriorated resulting in excessive movement (2.4.G.2)
Nearside Rear Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
Offside Front Front suspension has excessive play in a pin or bush of a lower wishbone inner bearing (2.5.B.1a)
Nearside Front Front suspension has excessive play in a pin or bush of a lower wishbone inner bearing (2.5.B.1a)
Emissions not tested (7.0)
Parking brake: efficiency below requirements (3.7.B.7)
- Test date 14 March 2012
- Expiry date 18 March 2013
- Test Result Pass
- Odometer reading 44,943 miles
- MOT test number 3784 9467 2017
Nearside Front Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Offside Front Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Nearside Rear Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Offside Rear Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Nearside Rear Shock absorber has a slightly worn bush (2.7.4)
Offside Rear Shock absorber has a slightly worn bush (2.7.4)
- Test date 10 March 2012
- Test Result Fail
- Odometer reading 44,811 miles
- MOT test number 1854 1017 2081
Offside Side repeater not working (1.4.A.2c)
Nearside Front constant velocity joint gaiter damaged to the extent that it no longer prevents the ingress of dirt etc (2.5.C.1a)
Nearside Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
Offside Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
Nearside Front Track rod end ball joint has excessive play (2.2.B.1f)
- Test date 17 March 2011
- Expiry date 18 March 2012
- Test Result Pass
- Odometer reading 37,643 miles
- MOT test number 9962 4607 1068
Nearside Front Seat belt anchorage prescribed area is corroded but not considered excessive (5.2.6)
- Test date 10 March 2011
- Test Result Fail
- Odometer reading 37,614 miles
- MOT test number 4967 4916 1049
Exhaust tailpipe not capable of allowing the emission probe to be inserted (7.3.D.1)
Front passenger door cannot be opened from outside the vehicle (6.2.B.1b)
Nearside Headlamp aim too high (1.8)
Offside Headlamp aim too high (1.8)
Nearside Headlamp insecure (1.7.3)
Offside Headlamp insecure (1.7.3)
Offside rear brake binding (3.7.B.1)
- Test date 15 March 2010
- Expiry date 18 March 2011
- Test Result Pass
- Odometer reading 35,920 miles
- MOT test number 4402 3487 0062
- Test date 10 March 2010
- Test Result Fail
- Odometer reading 35,916 miles
- MOT test number 1312 6976 0076
Fuel system component insecure (7.2.1)
- Test date 19 March 2009
- Expiry date 18 March 2010
- Test Result Pass
- Odometer reading 34,251 miles
- MOT test number 1837 8897 9448
Nearside Front Tyre worn close to the legal limit (4.1.E.1)
Offside Front Tyre worn close to the legal limit (4.1.E.1)
- Test date 18 March 2009
- Test Result Fail
- MOT test number 7433 6797 9058
Nearside Rear position lamp(s) excessively deteriorated so that it is not visible from a reasonable distance (1.1.A.3d)
Offside Rear fog lamp not working (1.3.2b)
- Test date 19 March 2008
- Expiry date 18 March 2009
- Test Result Pass
- Odometer reading 31,105 miles
- MOT test number 5906 1947 8087
- Test date 14 March 2008
- Test Result Fail
- MOT test number 7207 0457 8073
Nearside Front Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
- Test date 13 March 2007
- Expiry date 15 March 2008
- Test Result Pass
- Odometer reading 27,817 miles
- MOT test number 9124 6287 7068
Nearside Rear Torsion bar slightly deteriorated by corrosion (2.4.E.1b)
Offside Rear Torsion bar slightly deteriorated by corrosion (2.4.E.1b)
- Test date 12 March 2007
- Test Result Fail
- MOT test number 4422 6187 7054
Brake master cylinder fluid level below minimum level (3.6.G.1e)
- Test date 10 March 2006
- Expiry date 15 March 2007
- Test Result Pass
- Odometer reading 24,639 miles
- MOT test number 7306 8956 6044
